nathan.is.an.idiot12312 Posted August 16, 2023 Report Share Posted August 16, 2023 so im looking at buying a 1981 b210 but its an automatic and id prefer a manual. im wondering if i can pair a ca18 5 speed manual to the A14, and if so would i need a different driveshaft? then ill probably swap in a ca18det engine later on. Quote Link to comment
datzenmike Posted August 16, 2023 Report Share Posted August 16, 2023 The '81 was a B-310 commonly referred to as a 210. I'm not aware that this will work between two different series engines like the CA and the A. Measure the length of your automatic from the engine plate between the transmission and the engine back to the driveshaft. The CA18ET 5 speed is 31.5". Not sure if the A series drive shaft spline size will fit into the 71B 5 speed anyway. Swap them together later. Quote Link to comment
pdp8 Posted August 17, 2023 Report Share Posted August 17, 2023 If you are going to motor-swap, do the gearbox at that time. I think the starter is on the wrong side to even try to mate a CA box to an A motor. While you have a A-series, FS5W60 is the 5-speed for the 210. They are valuable partly because they can be fitted to MG MIDGET AH SPRITE cars, so expect to spend a grand for one, but otherwise they are a really good little gearbox. You'll need a master clutch cylinder, clutch slave cylinder, clutch pedal assembly, flywheel for a A-series motor, and motor adapter plate, along with the hardline and hose for the clutch. I think you need the transmission rear mount as well, but it's been a while. If you can find a donor car, it's not a bad swap at all, but if you have to do it part by part, it's annoying. I've done it in a 1980 210 and also a 1971 1200. The 1200 is vastly harder because the body is actually different. Quote Link to comment
Tom1200 Posted August 18, 2023 Report Share Posted August 18, 2023 The CA trans will not fit the A-series block. The aforementioned 60 series 5 speed is what you meed; they run between $500 - $1000 Quote Link to comment
datzenmike Posted August 18, 2023 Report Share Posted August 18, 2023 Both starters are on the right side. I think he plans a CA18DET swap later so better to wait and do it then. For now the automatic should do. Quote Link to comment
nathan.is.an.idiot12312 Posted February 28 Author Report Share Posted February 28 On 8/16/2023 at 8:31 PM, pdp8 said: If you are going to motor-swap, do the gearbox at that time. I think the starter is on the wrong side to even try to mate a CA box to an A motor. While you have a A-series, FS5W60 is the 5-speed for the 210. They are valuable partly because they can be fitted to MG MIDGET AH SPRITE cars, so expect to spend a grand for one, but otherwise they are a really good little gearbox. You'll need a master clutch cylinder, clutch slave cylinder, clutch pedal assembly, flywheel for a A-series motor, and motor adapter plate, along with the hardline and hose for the clutch. I think you need the transmission rear mount as well, but it's been a while. If you can find a donor car, it's not a bad swap at all, but if you have to do it part by part, it's annoying. I've done it in a 1980 210 and also a 1971 1200. The 1200 is vastly harder because the body is actually different. i spotted a red 1976-79 210 hatch sitting in a auto yard of some sorts between tucson and benson az, praying that its a 5 speed with under 200k miles cause my rings are fried and i dont feel like searching around for every individual part to do a rebuild it, hoping i can get the drivetrain for a steal, the car itself looked pretty sun damaged but otherwise really straight but i dunno, i only really caught a glimpse, but pray for me lol. my 210 is so clean i want to drive this thing into the ground like a grandma (also want to swap in a bigger engine as i mentioned before and put her on coils so i can slide around a bit but thats a ways in the future 🙂 Quote Link to comment
