720axr Posted June 18, 2023 Report Share Posted June 18, 2023 Hey all! Pretty new here and I wanted to get some info on swapping a bed. I have an 86 base model 720 single cab. I REALLY want to swap the bed for something like an 84 or so. I want the bed tie down look. What problems would I run into that wouldn't be so obvious? Any and all help is welcomed! Quote Link to comment
datzenmike Posted June 18, 2023 Report Share Posted June 18, 2023 Visually they don't match but otherwise they will swap. You would need the bed from an '84 king cab or another regular cab. What about swapping the '84 tie downs onto the '85? Quote Link to comment
NC85ST Posted June 18, 2023 Report Share Posted June 18, 2023 The rust look, in the body seams, also comes with the ‘84 or earlier bed. 1 Quote Link to comment
720axr Posted June 20, 2023 Author Report Share Posted June 20, 2023 On 6/18/2023 at 9:55 AM, datzenmike said: Visually they don't match but otherwise they will swap. You would need the bed from an '84 king cab or another regular cab. What about swapping the '84 tie downs onto the '85? Well my dilemma is I have a 86 stock with a bed without the tie down slot. I reallllllly love that look it's just something I really want. I almost thought about slapping em on the normal bed but gladly I didnt. Quote Link to comment
720axr Posted June 20, 2023 Author Report Share Posted June 20, 2023 On 6/18/2023 at 10:53 AM, NC85ST said: The rust look, in the body seams, also comes with the ‘84 or earlier bed. I'm not too sure I understand? Quote Link to comment
datzenmike Posted June 20, 2023 Report Share Posted June 20, 2023 The '85-'86 is a seamless one piece side design. Earlier trucks had a single upper piece, two lower pieces and the floor of the bed. They all meet at this horizontal spot welded seam and it rusts out. Quote Link to comment
powderfinger Posted June 20, 2023 Report Share Posted June 20, 2023 Yeah, I would stick with the 86 bed if it is in decent shape. Very difficult to find a pre-85 bed that isn't rusted out and if you do find one that looks good make sure it hasn't been painted before. In that case looks can be deceiving, the bed may be full of body filler. Quote Link to comment
720_Jeff Posted June 20, 2023 Report Share Posted June 20, 2023 This might be a decent picture of what is being described. Other side of the truck has the same rust lines, parallel to the ground. 1 Quote Link to comment
