Stoffregen Motorsports Posted May 5, 2023 Report Share Posted May 5, 2023 Depends on the look you're going for. I'd run 35x12.50s on them, but you may want a hellufresh look instead. Quote Link to comment
datzenmike Posted May 5, 2023 Report Share Posted May 5, 2023 First of all never buy rims and tires and then try to make them fit. Love can make you do crazy things. The rim offset will determine if rim and tire are too far in and hitting the suspension or too far out and the body coming down on them on bumps or rubbing on turns. You need to know this first. The stock tire is, I think, 26" diameter* so you want a 15" tire with that diameter and a width that doesn't rub anything. Assuming you were either lucky or you did some research and the rim fits the wheel wells then... 205/65R15 is 26" and 8" wide 230/60R15 is 26" and 9" wide 255/50R15 is 26" and 10" wide * keep the stock wheel diameter and the speedometer remains accurate and the acceleration performance unchanged. Quote Link to comment
Stoffregen Motorsports Posted May 5, 2023 Report Share Posted May 5, 2023 Why does he need a tire of the same diameter? He's obviously going the custom route. 1 Quote Link to comment
Stoffregen Motorsports Posted May 5, 2023 Report Share Posted May 5, 2023 The wheel he bought shows a 4" backspacing. On a 10" wide wheel, that's over 6" of wheel past center-line (wheel backspacing measures the lip of the rim too). This is what's called a heavy negative offset. I hate negative offset because of what it does to the wheels bearings and the scrub radius. My builds are obviously different than what @Joey is going for so I'm not going to bash him for his style taste, but I will warn that unless the front steering and suspension are in absolutely perfect condition, death wobble may be a consideration with such a wide wheel and negative offset. That said, I'd keep the tires small to reduce the rotating mass associated with death wobble. Quote Link to comment
datzenmike Posted May 5, 2023 Report Share Posted May 5, 2023 33 minutes ago, Stoffregen Motorsports said: Why does he need a tire of the same diameter? He's obviously going the custom route. 2 hours ago, datzenmike said: * keep the stock wheel diameter and the speedometer remains accurate and the acceleration performance unchanged. 3 hours ago, Stoffregen Motorsports said: I'd run 35x12.50s on them, but you may want a hellufresh look instead. wat????? I thought he said he was slamming it in the title. The tires definitely have to fit. I had 4" body lift and about a foot of suspension lift to get 33" under my 620. This included a Toyota SAS and F-150 re arched leaf springs on all four corners. Quote Link to comment
Stoffregen Motorsports Posted May 5, 2023 Report Share Posted May 5, 2023 I was kidding. Quote Link to comment
Stoffregen Motorsports Posted May 5, 2023 Report Share Posted May 5, 2023 And besides, guys and gals cut their bodies to fit tires these days. Quote Link to comment
datzenmike Posted May 5, 2023 Report Share Posted May 5, 2023 1 hour ago, Stoffregen Motorsports said: I was kidding. OHHHH 1 hour ago, Stoffregen Motorsports said: And besides, guys and gals cut their bodies to fit tires these days. Quote Link to comment
Joey Posted May 5, 2023 Author Report Share Posted May 5, 2023 How can I add pics of my truck I'm still new to this page Quote Link to comment
Joey Posted May 5, 2023 Author Report Share Posted May 5, 2023 https://photos.app.goo.gl/zWg2Q2zrAbdyhA6n7 Quote Link to comment
Joey Posted May 5, 2023 Author Report Share Posted May 5, 2023 Yea I'm going completely different and custom and just gonna use it for weekends cruise and put my bike on top of it . 1 Quote Link to comment
Stoffregen Motorsports Posted May 6, 2023 Report Share Posted May 6, 2023 6 hours ago, datzenmike said: OHHHH She is so hot. Quote Link to comment
datzenmike Posted May 6, 2023 Report Share Posted May 6, 2023 10 hours ago, Stoffregen Motorsports said: I was kidding. Not this time, I think. What is her super power again??? 1 Quote Link to comment
Dusten Posted May 6, 2023 Report Share Posted May 6, 2023 https://www.offfset.com/pages/wheel-fitment-calculator That site will give good representation of what fits. And how. 1 Quote Link to comment
Stoffregen Motorsports Posted May 6, 2023 Report Share Posted May 6, 2023 12 hours ago, datzenmike said: Not this time, I think. What is her super power again??? Mind control. Could be useful. I was thinking about her other roles in other movies though. Quote Link to comment
RyanC Posted May 8, 2023 Report Share Posted May 8, 2023 On 5/6/2023 at 6:08 AM, Joey said: Yea I'm going completely different and custom and just gonna use it for weekends cruise and put my bike on top of it . Nice flat tray mate! Beauty is you can fit some wide wheels back there!!! I'm in the same boat. PO put on 265's I think on 8 inch rims still haven't had them off to check. Next on the to do list. Quote Link to comment
