Roman arzate Posted April 26, 2023 Report Share Posted April 26, 2023 I like to know if there is a different centre support bearing I can install in my truck, I can't find any Quote Link to comment
datzenmike Posted April 26, 2023 Report Share Posted April 26, 2023 Only one confirmed bearing has ever gone bad. (metalmonkey) The bearings aren't the problem, it's the soft rubber surround that rots away. What I and several others have done is wrap a long strip of rubber belt around the stationery part, like a jellyroll, and clamp it down. Make sure it's snug. This part does not spin, the drive shaft spins inside, this just supports it. Mine was meant to be a temporary fir but it worked so perfectly I forgot about it for years. Never had a problem with it. I used a strip of conveyor belt but anything will do. Quote Link to comment
uberkevin Posted April 26, 2023 Report Share Posted April 26, 2023 I'm not sure I understand what you mean datzenmike. Quote Link to comment
Crashtd420 Posted April 26, 2023 Report Share Posted April 26, 2023 (edited) 10 hours ago, Roman arzate said: I like to know if there is a different centre support bearing I can install in my truck, I can't find any The stock one doesn't exist anymore.... I did a write up and test fit with another ratsun member and a replacement... I'll find the thread and link it.... Edited April 26, 2023 by Crashtd420 Quote Link to comment
Crashtd420 Posted April 26, 2023 Report Share Posted April 26, 2023 Go past the first idea, the second one is the better choice.. cheaper and available.... Quote Link to comment
