72 CnC_WaGon Posted December 12, 2008 Report Share Posted December 12, 2008 i found some loose wires coming off of the conncetor for the ignition switch and i dont know where they go can someone help me please thanks Quote Link to comment
datzenmike Posted December 12, 2008 Report Share Posted December 12, 2008 (edited) Pin position in connector: 1 White/Red comes from regulator, hot at all times. 2 Black/White is a switchable power source to the fuse box, power to coil ballast resistor in run position. 3 Black/Yellow to starter solenoid. 4 Blue/Black accy. and run power to fuse box for washer/wiper motor. 5 Black/Blue power to coil in start position. Edited December 12, 2008 by datzenmike Quote Link to comment
banzai510(hainz) Posted December 12, 2008 Report Share Posted December 12, 2008 i found some loose wires coming off of the conncetor for the ignition switch the wires just fell out? Quote Link to comment
hang_510 Posted December 12, 2008 Report Share Posted December 12, 2008 not ID'd in the schematic red wires are for the IG key buzzer Quote Link to comment
72 CnC_WaGon Posted December 13, 2008 Author Report Share Posted December 13, 2008 thank you guys i ll let you know what happens thanks again Quote Link to comment
72 CnC_WaGon Posted December 13, 2008 Author Report Share Posted December 13, 2008 ok guys can some tell me where the wires go on the connector .starting form the top(from behind where the wires go in) where there is only two slots just to make sure i didnt mess it up Quote Link to comment
72 CnC_WaGon Posted December 13, 2008 Author Report Share Posted December 13, 2008 nevermind i got it from the diagram u guys gave me thanks Quote Link to comment
