SWFL Posted February 12, 2023 Report Share Posted February 12, 2023 For a 1978 620, is the power wire for the cigarette lighter socket blue with a white stripe and a female butt connector? Does the cigarette lighter socket ground on the metal dash frame? Quote Link to comment
Stoffregen Motorsports Posted February 12, 2023 Report Share Posted February 12, 2023 Cigarette lighters use a lot of amps. Is the wire big? Grounding a lighter through the body is very common, but most of them have a male spade connector built into the housing, which can be used to add another ground. Quote Link to comment
SWFL Posted February 12, 2023 Author Report Share Posted February 12, 2023 It looks like 14 ga. My truck is missing the socket, so I'm not sure how it should be wired up. Quote Link to comment
datzenmike Posted February 12, 2023 Report Share Posted February 12, 2023 2 hours ago, SWFL said: For a 1978 620, is the power wire for the cigarette lighter socket blue with a white stripe and a female butt connector? Does the cigarette lighter socket ground on the metal dash frame? Yes, yes and yes. It does not need the ignition on to blaze one up. 3 Quote Link to comment
Stoffregen Motorsports Posted February 13, 2023 Report Share Posted February 13, 2023 I knew Mike would have the answer. Quote Link to comment
