Payco Posted May 20, 2022 Report Share Posted May 20, 2022 Guys . Any ideas where I might be able to acquire one or does someone have one I can buy from them. It would appear there is a front left/right and centre main cable but it’s the centre main I need. A few companies appear to sell them but they aren’t clear and aren’t responding to my emails. Is it the same as the cable used on the 240z ? Or specific to the 510 ?. Thanks in advance. Martin Quote Link to comment
datzenmike Posted May 20, 2022 Report Share Posted May 20, 2022 There are different ones for the automatic. I assume you have right hand drive? and the hand brake is located centrally ahead of the shifter? Even so it may be slightly to the right of center than a LHD car. The long central cable for a LHD 510 is 36402-21401. 1 Quote Link to comment
Payco Posted May 20, 2022 Author Report Share Posted May 20, 2022 (edited) Thanks again Mike. Yes mine is RHD , manual and it’s mounted slightly off to the right of the gear lever. Does anyone know where I can find this part ? Thanks Martin Edited May 20, 2022 by Payco Quote Link to comment
yenpit Posted June 2, 2022 Report Share Posted June 2, 2022 I should have a USA spec LHD front cable USED (second hand). If you look at your e/brake handle assembly at the firewall, you will see that the front cable is "peened" in place on the handle base assembly. I'm not sure how you could UN-peen it without cutting into the handle base where it is peened.......?? I bet the front cable is the same, just moved over to the right side.......?? I should also have the other USA spec cable parts. Let me know if I can help! TJ 1 Quote Link to comment
