Thomas Perkins Posted April 3, 2022 Report Share Posted April 3, 2022 (edited) You think gas is high,wait till you change your oil.I went to O'Reilly's and got a Wix 5151 oil filter, it is with tax 14.04,use to be 9 bucks,I went to Walmart and got 5 quarts of 10W30 Castrol for 26.47 with tax,use to be 19.00 bucks.Time to impeach ole man Biden.Donald had everything stable.Things will change in 2024.We are still Red here in Georgia...Tax here is 9 cent on the dollar.But we can tote a gun without a permit...Save money,use a 357,only takes one bullet...and take no prisoners..That's why Barney fife only had one bullet...I painted Barney...Also that bench behind him... Edited April 3, 2022 by Thomas Perkins Quote Link to comment
powderfinger Posted April 4, 2022 Report Share Posted April 4, 2022 Yeah I just recently posted about the rear window seal from vintagerubber.com. I meant to order it last week and didn't. It was $90 then, I just went to order one last night and it is now $110. I guess that's what I get for procrastinating and not ordering it last week. Quote Link to comment
DuallyDatsun Posted April 4, 2022 Report Share Posted April 4, 2022 It's been at least a decade and a half since I could do a $10 oil change. I remember back in the early 00's having sales at Oreilly's and stuff where you get 4qts and a filter for $10 for store brand, or $15 for the primo stuff. 4qt Valvoline jugs were only about $10 by themselves. Quote Link to comment
datzenmike Posted April 4, 2022 Report Share Posted April 4, 2022 Make sure you get an oil with high ZDDP anti scuff levels over 1,000 PPM. Chevron Delo 400, Shell Rotella T4 in 10w30 or even 15w40 if in southern hot states will supply this. They are both a 'light' diesel oil. There are others. Over the counter oils marked for 'racing' or 'flat tappet' engines are also good. Not a fan of synthetic in older engines. Not worth the expense and not needed on older design engines that have no problem with cold start up oil flow. Not like new engines with smaller bearings. 1 Quote Link to comment
