frankendat Posted March 18, 2022 Report Share Posted March 18, 2022 Gentlemen, I haven't seen for sale in a while. Will this adjustable sprocket work for a Z24? I think I have mentioned this before, but couldn't find the thread https://www.rhdjapan.com/kameari-full-adjustable-cam-pulley-sprocket-gear-l18-l20-l26-l28.html Quote Link to comment
datzenmike Posted March 18, 2022 Report Share Posted March 18, 2022 It's an insane amount for something that you won't even feel on a stock engine. Quote Link to comment
frankendat Posted March 19, 2022 Author Report Share Posted March 19, 2022 19 hours ago, datzenmike said: It's an insane amount for something that you won't even feel on a stock engine. Thank you for responding, I value your council. My thought was if I employ an knock sensor, then I may benefit from advanced timing, The only gain sought by seeing how far I could advance was improved mpg. My engine is far from stock, but modifications focus on torque and low end power. Do you believe there is enough timing advance available to accomplish any possible gains, without an adjustable timing sprocket? Quote Link to comment
datzenmike Posted March 19, 2022 Report Share Posted March 19, 2022 What are those kalamaari adjustable sprockets? $300 or $600. I was going to say that's a lot of driving to pay back. Gotta figure Nissan probably has the timing close for mileage/power compromise. I know as the chain wears the valve events happen sooner There are 3 adjustment holes in the cam sprocket for retarding the cam timing from induced advancing from a worn chain or having the head milled. Each hole is 4 degrees. L20B and up are factory set at the #2 hole. Moving to #3 retards 4 degrees. #1 advances. You could move one tooth, that's 9 degrees. Try this and see if you notice anything, I doubt you will. It's something only a dyno will confirm. IIRC a stretched chain tends to gain at higher RPMs and looses some low speed torque. 1 Quote Link to comment
Stinky Posted April 5, 2022 Report Share Posted April 5, 2022 (edited) Waste of money. You can get all the ignition timing that you need in the dizzy's bracket. They is no advantage to ignition advance, because you can only go so far and it will start pre-ignition (pinging), add a little more, and it will sound like you are making popcorn. That said, there is a guy on here that re-curve dizzys for more advance. They make the same sort of thing for SBCs. They used to make them for Pinto engines and they make them for Type I VW engines. The people that make them talk about how great they are. I have learned....you move the whole power curve down in rpms about 200 rpm per each 4 degrees advanced or up 200 for each 4 degrees retarded from its stock index location Also, there are no gains to be made over an ignition system that is functioning well....in a stock motor. That said, if you couldn't help yourself, I'd put on the cheap MSD box Summit sells one of their brand, that is a bit cheaper, that sounds similar. Accel also makes one https://www.jegs.com/i/MSD-Ignition/121/5520/10002/-1 Edited April 5, 2022 by Stinky Quote Link to comment
datzenmike Posted April 5, 2022 Report Share Posted April 5, 2022 This is for adjusting the cam timing not the ignition timing. 1 Quote Link to comment
