pidge Posted November 25, 2023 Report Share Posted November 25, 2023 Looks stamped I’m pretty sure. If anyone has a frame set I may be your guy. Thanks. Quote Link to comment
Jakes Makes Posted January 7 Author Report Share Posted January 7 On 10/29/2023 at 4:23 AM, pidge said: Ooohhhhhhh! I like nice job. My ‘69 has the shorter lights and I think the longer ones look better filling the gap on each side of the license plate. I’d love to get a set, buuut I’m gonna wager I need the later mounting plate/bracket correct? Do you or anyone happen to have a picture or a few of the mounting plate/bracket I could have a look at? Maybe I could cobble up something outta metal. -Pidge I was thinking about making them previously and the plan I came up with was to use some small steel angle and cut it at 45* and weld it up. The only more challenging part was how to get the studs welded on the inside without creating clearance issues during assembly. 1 Quote Link to comment
Jakes Makes Posted January 7 Author Report Share Posted January 7 The stars aligned and I am finally able to sell complete sets of 521 clear or OEM colored lenses if anyone is interested. I can also sell separately if needed. 1 Quote Link to comment
Jakes Makes Posted January 7 Author Report Share Posted January 7 In case anyone wants some inspiration... 2 Quote Link to comment
pidge Posted January 8 Report Share Posted January 8 What do you charge for a set of tail lights Jake? Quote Link to comment
Jakes Makes Posted January 8 Author Report Share Posted January 8 23 minutes ago, pidge said: What do you charge for a set of tail lights Jake? Whether clear or OEM style I typically do $220 with free shipping in the US. For Canada I can run a quote if you're interested. Quote Link to comment
pidge Posted January 9 Report Share Posted January 9 OEM style, not a fan of the clears. Run me a quote when you get time. (Ontario, Canada) Thanks. -Pidge 1 Quote Link to comment
