IHaveNoIdeaWhatIAmDoing Posted October 25, 2020 Report Share Posted October 25, 2020 I have been looking for some mounts for my 83 720 4x4 and on the engine mounts that I have found, it specifies that it is for rear wheel drive and I was just wondering if there was a difference between the engine mounts for the 4x4 and the 2 wheel. Also I have been unable to locate transfer case mounts and was wondering if anyone knew where I could find some. 1 Quote Link to comment
datzenmike Posted October 25, 2020 Report Share Posted October 25, 2020 The '83 and up 2wd and 4x4 mounts are different. 1 Quote Link to comment
Stoffregen Motorsports Posted October 25, 2020 Report Share Posted October 25, 2020 Sometimes using loose terms on a google search helps you zero in on what you need. I searched 1983 Nissan 720 motor mount bushing on google and came up with these results - https://www.nissanpartsdeal.com/oem-nissan-720_pickup-engine_mount.html https://www.summitracing.com/parts/ani-2718/applications/make/nissan/model/720/drivetrain/4wd Do any of these look correct? 1 Quote Link to comment
