EStop Posted September 23, 2020 Report Share Posted September 23, 2020 Looking for information for a CA18DET Swap. From what it seems all the same issues a KA present in dropping in a CA also does. The one thing I really want to know is if the KA24DE motor mounts that Redeye sells also work with the CA18DET or will some fabrication need to be done to make my own mounts? The reason I am going CA is because I found a motor for cheap with all the right stuff and I was going the turbo KA route prior. The CA just happens to be a much better deal even if it means a bit more fabricating. Thanks! Quote Link to comment
breezenahan Posted October 1, 2020 Report Share Posted October 1, 2020 welcome to the forum, i found this thread from the 510 realm,http://www.the510realm.com/viewtopic.php?t=9693 but i would caution against going CA, parts are hard to find for this motor as most people go SR. if i had to be honest keeping an eye out for a good KA is the way to go. readily available information along with a lot better parts availability. the CA is a neat little motor, but the KA will make more power for less money over the long run. 1 Quote Link to comment
]2eDeYe Posted October 1, 2020 Report Share Posted October 1, 2020 The engine side bolt patterns are different between the CA, KA and SR. My mounts would work as far as I know. If I had a truck and a CA or possible a set of 200sx CA engine mounts I could design a set. Quote Link to comment
willz Posted November 13, 2021 Report Share Posted November 13, 2021 On 10/1/2020 at 11:18 AM, ]2eDeYe said: The engine side bolt patterns are different between the CA, KA and SR. My mounts would work as far as I know. If I had a truck and a CA or possible a set of 200sx CA engine mounts I could design a set. I’m picking up a CA18det today for my 620 if you need something 1 Quote Link to comment
]2eDeYe Posted November 15, 2021 Report Share Posted November 15, 2021 Some pics would be cool to start 🙂 Quote Link to comment
