84 720 4WD parking brake cable needed
Regenerative
  • Replies 4
I had the same problem with mine. Too long can be shortened. I ended up taking about 9" out of the cable sheath and re-fitting the sheath into the fitting. The cable "ball" end needs to be properly soldered back onto the cable the same amount as you shortened the sheath.
