datzenmike Posted August 25, 2009 Report Share Posted August 25, 2009 This is an old thread. Quote Link to comment
Mike Phillips Posted November 12, 2009 Author Report Share Posted November 12, 2009 For what it's worth... I had the original radiator re-cored and now it never goes past about 1/4 on the temp guage... Runs great! :) Quote Link to comment
dimedriver Posted November 13, 2009 Report Share Posted November 13, 2009 What alternator did you end up getting at napa? I have had good luck getting 240sx alternators at the pick and pull and having them rebuilt with a V belt pulley on them. Nissan used pretty much the same mounting scheme forever. The 240sx alternator is around 90amps. If you need more power you can use the minivan's. I think it more than 120amp. I end up using a longer bolt on the top and putting an extra nut to lock the bolt in. For my L16 I had the holes drilled and tapped for M10 bolts. The L18's and 20's should already have the beefer bolts. -Dime Quote Link to comment
