Traumatized3 Posted May 6, 2020 Report Share Posted May 6, 2020 The turn signals will not fully engage. I think there is too much dirt or something keeping it from engaging. Where can I pick up a replacement? I bought one from Autozone, but it was too big and didn't fit. Thanks guys! 1 Quote Link to comment
datzenmike Posted May 7, 2020 Report Share Posted May 7, 2020 Get a can of electrical contact cleaner and lubricant and sprat the shit out of it. Remove from the steering column. The grease gets dry with age and it collects dirt. Headlight switch does the same thing. 1 Quote Link to comment
captain720 Posted May 7, 2020 Report Share Posted May 7, 2020 Auto parts mostly likely sold you a D21 assembly. They are larger and don't fit right. If you can't fix the assembly it is possible to replace only the back half of the assembly with a different socket if you hack it a bit. 1 Quote Link to comment
Stinky Posted May 8, 2020 Report Share Posted May 8, 2020 (edited) If that doesnt work...Napa. There are 2 columns, the PS tilt column and the non PS non tilt column. I think, not sure, that the tilt column came w.PS and Interval Wiper, and the other didnt. Edited May 8, 2020 by Stinky 1 Quote Link to comment
Stinky Posted May 11, 2020 Report Share Posted May 11, 2020 https://www.napaonline.com/en/p/ECHHL6741?partTypeName=Turn+Signal+Switch&keywordInput=combination+switch 1 Quote Link to comment
