Payco Posted April 27, 2020 Report Share Posted April 27, 2020 Guys. got myself a nice SSS original steering wheel. Are these easy enough to fit having removed the current wheel. Any particular process for removing to follow. I have all the screws with it. Martin Quote Link to comment
BrandonS Posted April 28, 2020 Report Share Posted April 28, 2020 (edited) It's literally just taking a medium sized nut off of the steering column, pulling the wheel off (i had to wiggle while pulling for mine) and then putting the new one on and tightening the nut down. If it's the faux wooden one, i'd recommend "restoring" it before you stick it on. It's a really easy process. You just take steel wool scouring pads and scrub it until all the old lacquer comes off. Once that's off you just put a few coats of clear lacquer over it. Done. It's also a good time to repaint the center part. Before: After: Edited April 28, 2020 by BrandonS 3 Quote Link to comment
Payco Posted April 30, 2020 Author Report Share Posted April 30, 2020 (edited) Thanks for the reply. I have an original like the above which I have fully restored myself. Edited May 1, 2020 by Payco 1 Quote Link to comment
Payco Posted May 1, 2020 Author Report Share Posted May 1, 2020 Photo added, better in the flesh.. Quote Link to comment
Ranman72 Posted May 3, 2020 Report Share Posted May 3, 2020 if you cant wiggle the stock wheel loose take a center punch on the column leave the nut on loose tap with a hammer not super hard but firm strikes usually this process will free up the wheel the reason for leaving the nut is if pulling hard on the wheel you might hit yourself in the face when it breaks free 1 Quote Link to comment
