dans521 Posted April 19, 2020 Report Share Posted April 19, 2020 busy doing an engine and disc brake upgrade on my ute, ill be using kyb gasa just shocks but my ute has no sway bar, and living in new zealand 521 and even 620s are pretty rare i was wondering if there was another sway bar i could use? someone is selling a cheap b310 sway bar and was wondering if that would work? Quote Link to comment
wayno Posted April 19, 2020 Report Share Posted April 19, 2020 All you can really do is measure how wide apart the lower control arm connections are and find something around the same width, but you also have another issue, mounting the sway bar to the frame rails, you need that hardware also. I didn't have a sway bar on my 521 work truck for 15 years as it interfered with my power steering setup, I never even noticed it wasn't there. Quote Link to comment
mainer311 Posted April 19, 2020 Report Share Posted April 19, 2020 If you really want a sway bar, Futofab here in the US has them. https://www.futofab.com/index.php?option=com_content&view=category&layout=blog&id=39&Itemid=125 1 Quote Link to comment
banzai510(hainz) Posted April 19, 2020 Report Share Posted April 19, 2020 I puta bigger one on my 521 i think it was. Addco brand. 1 Quote Link to comment
dans521 Posted April 20, 2020 Author Report Share Posted April 20, 2020 6 hours ago, wayno said: All you can really do is measure how wide apart the lower control arm connections are and find something around the same width, but you also have another issue, mounting the sway bar to the frame rails, you need that hardware also. I didn't have a sway bar on my 521 work truck for 15 years as it interfered with my power steering setup, I never even noticed it wasn't there. The guy said their is 1 meter between the to mounting points and that roughly lines up, also going to check a 620 sway bar from. A guy doing a vq37 swap on his 620 1 Quote Link to comment
dans521 Posted April 20, 2020 Author Report Share Posted April 20, 2020 3 hours ago, banzai510(hainz) said: I puta bigger one on my 521 i think it was. Addco brand. Notice any difference and have you got a rear sway bar? Or no pint would you say, I've removed a couple leaf springs and have put a flat deck on my ute, extremely rare ute in new Zealand for me so getting parts isn't easy 1 Quote Link to comment
banzai510(hainz) Posted April 20, 2020 Report Share Posted April 20, 2020 Yes I did notice a difference i also got some KYB Gas A Just also i have no rear sway bar i usually get stuff on discount when somebody is selling cheap. I think it was 100$ almost 15 years ago but was new 1 Quote Link to comment
