Droski Posted October 2, 2019 Report Share Posted October 2, 2019 So my clutch pedal is soft and has lost all resistance when engaged ( 1975 620 ) Quote Link to comment
bilzbobaggins Posted October 2, 2019 Report Share Posted October 2, 2019 Is there fluid still in it? Quote Link to comment
Droski Posted October 2, 2019 Author Report Share Posted October 2, 2019 Yes looks a little over half full, the fluid looks pretty brown though Quote Link to comment
bilzbobaggins Posted October 2, 2019 Report Share Posted October 2, 2019 (edited) Must have gave up the ghost then. Could try flushing and bleeding for shizt n giggles. Edited October 2, 2019 by bilzbobaggins Quote Link to comment
datzenmike Posted October 2, 2019 Report Share Posted October 2, 2019 May have trapped air in it. Air compresses easily and causes a soft pedal. There is a bleeder on the slave to let the air out. Bleed the hydraulic system first. This will replace the old fluid with new and remove any trapped air. Quote Link to comment
banzai510(hainz) Posted October 2, 2019 Report Share Posted October 2, 2019 do as mike suggested open the bller and see if fluid goes the slave. I also put my finger in the master cylinder and plug the hole and have someone pump the pedal .It might create a suction . then rebleed the system again Quote Link to comment
Droski Posted October 3, 2019 Author Report Share Posted October 3, 2019 okay guys thanks for the help ill try these methods this weekend if not soon ill come back with an update Quote Link to comment
