Madkaw Posted September 10, 2019 Report Share Posted September 10, 2019 Basically flashes once when I under hard acceleration. Not every time , but more than a few times. Still breaking in a fresh motor and I thought it might be the oil light flashing, but it’s the brake light. Never comes on while braking. Quote Link to comment
datzenmike Posted September 10, 2019 Report Share Posted September 10, 2019 First of all it's a 720 so there is no hard acceleration 😄 Check the brake master reservoirs. Some 720s have a floating sensor for low fluid. Acceleration with low fluid may turn it on Make sure the hand brake is all the way off. Perhaps adjust the rear emergency brakes. Both of the above are connected to the red light. There is also a pressure switch but this would not likely be involved accelerating. 2 Quote Link to comment
Madkaw Posted September 10, 2019 Author Report Share Posted September 10, 2019 18 hours ago, datzenmike said: First of all it's a 720 so there is no hard acceleration 😄 Check the brake master reservoirs. Some 720s have a floating sensor for low fluid. Acceleration with low fluid may turn it on Make sure the hand brake is all the way off. Perhaps adjust the rear emergency brakes. Both of the above are connected to the red light. There is also a pressure switch but this would not likely be involved accelerating. It’s a fresh rebuild, so it’s a hard acceleration —-for a 720-lol. Nice low end torque from the little booger. I didn’t expect much since I’ve never owned or driven one until now. Just happy it fires off every time and idles nice. You do have to slam he throttle to get any acceleration from the Weber. Probably only have 50 miles on the engine so no gear slamming yet -lol Quote Link to comment
datzenmike Posted September 11, 2019 Report Share Posted September 11, 2019 Don't baby a new engine. DRIVE it and it will seat the rings sooner and better. 1 Quote Link to comment
Charlie69 Posted September 12, 2019 Report Share Posted September 12, 2019 If you have a new cam follow the cam manufacturers brake in procedures. If not drive it like you stole it! If the rebuild was done correctly and quality parts were used your rings will seat fine. Quote Link to comment
datzenmike Posted September 12, 2019 Report Share Posted September 12, 2019 I don't think there is a break in procedure for a Nissan cam. V8s rely on oil thrown off by the crank and why you are supposed to rev to 3K? for 20 min. Nissan has more than adequate forced oiling of their cams and rockers. As the cam has no idea how hard you are stepping on the gas you can drive as you like 1 Quote Link to comment
Madkaw Posted September 12, 2019 Author Report Share Posted September 12, 2019 Good call on the brake light Mike. MC was not low at all, it just low enough that the bobber was setting off the light. Driving it normally at this point. Plugs are cleaning up nicely, but look a bit lean . I’ll put more miles on it before I make the call on mixture . Wouldn’t need a break in period on a used cam . This is engines have a normal tick noise. Not loud at all, quite subtle . Never gets worse or better. I’m thinking solid lifter cam engine sound . 1 Quote Link to comment
