izzo Posted November 19, 2008 Report Share Posted November 19, 2008 first, is the cowl sealed on on the 1980 720's. I dont see any screws for it. And it just flops around under the window. But the part towards the firewall is solid and i dont see any screws. Also, I looked thru the forums and even checked around online. Looks like DA Sanders, some people prefer them, some dont. Most things i read said its ok just be careful around the edges, is that because if you catch the bodyline it will take a chunk out? Someone told me once to use aircraft remover. It worked ok but took a shitload and seems to cost more then worth it. I have a few wire wheels, is it ok to use those to get the paint down to thin layers or all the way down to metal?? Quote Link to comment
datzenmike Posted November 19, 2008 Report Share Posted November 19, 2008 The cowl comes off because I removed the wiper pivots and used them on my 620. There are 4 screws in front where the hood meets it. You have to remove the wiper arms first. Quote Link to comment
izzo Posted November 19, 2008 Author Report Share Posted November 19, 2008 thanks mike ill take a look at it friday morning hopefully. Anyone else know about the sander part? Some good news too. Payday is the 25th, i should have tabs on my rig within a few days after. Itll be my new daily. Quote Link to comment
freaky510 Posted November 20, 2008 Report Share Posted November 20, 2008 A d/a will work fine.you just need to keep it moving.i stripped a roadster with the aircraft remover. it works great if you follow the directions(brush in 1 direction and dont go over the same wet spot twice). it took a gallon to do the whole car.It does take awhile but no dust. i prefer hand sanding over power tools thats why i used the stripper and hand sanded the tuff areas.Do you have an air compressor??If you do and it can keep up get some air tools Quote Link to comment
izzo Posted November 20, 2008 Author Report Share Posted November 20, 2008 Sounds good. Dont have an air compressor, in laws where i will be at in seaside have a little one. Not sure how well it will keep up. With the DA sander, is that so you dont sand down the metal? And with the air craft remover, did you just use a plastic scraper? I did this on my courier and man what a pain LOL. I will give it a shot. I have a paint theme i want to do for the truck, itll be rattle can but should look alright once done. Quote Link to comment
freaky510 Posted November 20, 2008 Report Share Posted November 20, 2008 with sanding you can stop when you want. if your just going to re-paint it. scuff the paint really good get a good primer on it and start over.no real need to take it all the way down for a rattle can job. IMO Quote Link to comment
510er Posted November 21, 2008 Report Share Posted November 21, 2008 i agree all you need to do is smooth out whats on there with a good scuff job Quote Link to comment
