datzenmike Posted November 26, 2008 Report Share Posted November 26, 2008 (edited) Make sure the distributor has a good ground connection. Some have a separate ground wire and terminal. Also the little black box can be cleaned on the back side to make good(er) ground connection to the distributor body. Hope you kept the old ones... this may be all that wrong with them. mike Edited November 26, 2008 by datzenmike Quote Link to comment
moparvwfreak Posted November 26, 2008 Report Share Posted November 26, 2008 i'll make a new ground for it. it didn't ahve one attached when i pulled it out ofthe yard so i will have to make it. i also pulled the box and cleaned the terminals on it, all 4, and cleaned the mount points on the dizy itsself. Quote Link to comment
datzenmike Posted November 26, 2008 Report Share Posted November 26, 2008 You can run the points coil, but use the resistor or it will overheat. Best to use the lower resistance EI one made for the matchbox dizzy. With EI open the plug gap to about 0.040". The higher output can easily jump more gap and this gives a physically longer spark. Widening the plug gap will put an added strain on the wires, cap and rotor, so if they are old they may not handle it. Quote Link to comment
Cuts metal like mad Posted November 26, 2008 Report Share Posted November 26, 2008 I only have the control boxes themselves available... I doubt you dizzy is bad, give me $20 for the coil and 2 boxes and call it good. Quote Link to comment
moparvwfreak Posted November 26, 2008 Report Share Posted November 26, 2008 You can run the points coil, but use the resistor or it will overheat. Best to use the lower resistance EI one made for the matchbox dizzy. With EI open the plug gap to about 0.040". The higher output can easily jump more gap and this gives a physically longer spark. Widening the plug gap will put an added strain on the wires, cap and rotor, so if they are old they may not handle it. i have to hit a yard to get the proper coil which is why i was wondering about the rabbit coil. plugs are gapped to .042 according to the specs on olddatsuns.com. all the rest of the parts are new with the exception of 1 plug. it broke when i pulled it to check the spark. I only have the control boxes themselves available... I doubt you dizzy is bad, give me $20 for the coil and 2 boxes and call it good. i will definatley do that once i get some $$ together. Quote Link to comment
