76_620 Posted August 2, 2019 Report Share Posted August 2, 2019 Are datsun 510 4 door and 2 door window elevators compatible ? Quote Link to comment
john510 Posted August 2, 2019 Report Share Posted August 2, 2019 Do you mean regulator ? I don't think they are. Quote Link to comment
76_620 Posted August 3, 2019 Author Report Share Posted August 3, 2019 3 hours ago, john510 said: Do you mean regulator ? I don't think they are. Yes the regulator Quote Link to comment
datzenmike Posted August 3, 2019 Report Share Posted August 3, 2019 By part numbers they are different. In reality the glass has to move up and down the same amount. The window wind up is likely in the same position. Seems to me I would use the same gears and cranking mechanism if I was Nissan, why re-invent the wheel? The biggest difference between 2 and 4 door is the glass is longer. The regulator works somewhat like a scissor jack. The scissor arms are probably the difference. 1 Quote Link to comment
76_620 Posted August 3, 2019 Author Report Share Posted August 3, 2019 2 hours ago, datzenmike said: By part numbers they are different. In reality the glass has to move up and down the same amount. The window wind up is likely in the same position. Seems to me I would use the same gears and cranking mechanism if I was Nissan, why re-invent the wheel? The biggest difference between 2 and 4 door is the glass is longer. The regulator works somewhat like a scissor jack. The scissor arms are probably the difference. Ahhhhh, ok. Thanks ! Ima keep looking for the correct one then. Thanks Quote Link to comment
