Orange620 Posted November 17, 2008 Report Share Posted November 17, 2008 There's a 79 620 in the Pick n Pull. The shift lever has already been taken. Were all 79 620s with manual, 5 speed? How can you ID it by just looking at it while its installed, that its a 5 speed and not a 4? Quote Link to comment
datsunaholic Posted November 17, 2008 Report Share Posted November 17, 2008 4-speeds had a cover plate just forward of the shifter. 5-speeds did not. '79s came standard with a 4-speed. Quote Link to comment
jefe de jefes Posted November 17, 2008 Report Share Posted November 17, 2008 Do you have a 4 speed? I think the 5 speed is like 4 inches longer. Quote Link to comment
datzenmike Posted November 17, 2008 Report Share Posted November 17, 2008 There's a 79 620 in the Pick n Pull. The shift lever has already been taken. Were all 79 620s with manual, 5 speed? How can you ID it by just looking at it while its installed, that its a 5 speed and not a 4? No the 4 speed was standard and the 5 speed was an option in '79. It is very easy to tell them apart but you will have to climb under it, to look. The 4spd will have a narrow (2" X 6") inspection plate with 6 bolts holding it on plus a small plastic vent. It's located on the top of the tail stock just in front of the shifter. Here is a 4spd: Look just ahead of the shifter for the narrow cover plate with 6 bolts. This definitively identifies it as a 4spd F4W71B. http://i138.photobucket.com/albums/q251/datzenmike/transF4W71Blongtail1.jpg[/img]"] http://i138.photobucket.com/albums/q251/datzenmike/transF4W71Blongtail3.jpg[/img]"] Quote Link to comment
Llittle_Llama Posted November 17, 2008 Report Share Posted November 17, 2008 4-speeds had a cover plate just forward of the shifter. 5-speeds did not. '79s came standard with a 4-speed. yeah, the 79's had a 5 speed as optional... Quote Link to comment
datzenmike Posted November 17, 2008 Report Share Posted November 17, 2008 Do you have a 4 speed?I think the 5 speed is like 4 inches longer. The 'new' 620 4spd F4W71B was first used in the '74 truck and is 31.5" long. The 'new' 5spd FS5W71B became an option in '77 and is the same length.... so, a 5spd can be swapped into any 4 spd '74-'79 truck without mods. Quote Link to comment
Orange620 Posted November 17, 2008 Author Report Share Posted November 17, 2008 The 4spd will have a narrow (2" X 6") inspection plate with 6 bolts holding it on plus a small plastic vent. It's located on the top of the tail stock just in front of the shifter. I'll look for the cover plate to ID it as a 4 speed. Thanks Quote Link to comment
BarryA Posted November 18, 2008 Report Share Posted November 18, 2008 There's a 79 620 in the Pick n Pull. The shift lever has already been taken. Were all 79 620s with manual, 5 speed? How can you ID it by just looking at it while its installed, that its a 5 speed and not a 4? pulled a number of parts (including the speedo cable) off it on Saturday...... Quote Link to comment
Orange620 Posted November 18, 2008 Author Report Share Posted November 18, 2008 pulled a number of parts (including the speedo cable) off it on Saturday...... If the one in Fairfield is a 4 speed, I'll probably go to Rancho Cordova. Quote Link to comment
