CamoKing Posted June 13, 2019 Report Share Posted June 13, 2019 This '82, 720 w/Z22 has four threads milled around the oil filter mount. I find nothing other than the block surface on which the oil filter gasket rests. Are these threads there for a part I am missing? A Spacer flange? Specialized mating surface?? Just curious. What gives? If it is a part, can I get it somewhere? Thanks in advance for any comments. 1 Quote Link to comment
Crashtd420 Posted June 13, 2019 Report Share Posted June 13, 2019 7 minutes ago, CamoKing said: This '82, 720 w/Z22 has four threads milled around the oil filter mount. I find nothing other than the block surface on which the oil filter gasket rests. Are these threads there for a part I am missing? A Spacer flange? Specialized mating surface?? Just curious. What gives? If it is a part, can I get it somewhere? Thanks in advance for any comments. You can bolt a remote oil filter set up to that if you wanted to .... that all... 1 Quote Link to comment
CamoKing Posted June 14, 2019 Author Report Share Posted June 14, 2019 Remote oil filter __?? What is it? Is there any advantage to having one? 1 Quote Link to comment
datzenmike Posted June 14, 2019 Report Share Posted June 14, 2019 You can mount a 280zx turbo automatic oil cooler adapter. The 4 threaded holes allow you to clock the adapter to get it where you want it. 1 Quote Link to comment
CamoKing Posted June 14, 2019 Author Report Share Posted June 14, 2019 So, really this is only for a turbo charged engine......(what would I do with all that HP!?!?) Quote Link to comment
datzenmike Posted June 14, 2019 Report Share Posted June 14, 2019 No.... but it is used on them. The KA also has a weird adapter that fits it for the oil pressure sender and to clock the filter for clearance. Quote Link to comment
