az_rat210 Posted March 24, 2019 Report Share Posted March 24, 2019 My B210 has an insulator that went with the hitachi. I have been using it with my weber, but I have to make more gaskets when they dry out. My question is this: Will paper gaskets provide sufficient heat insulation between the intake and the weber so that I do not need to use the insulator? So instead of having a gasket-small heat shield - gasket - insulator - gasket - adapter - gasket - weber, I could just go gasket - adapter - gasket - weber? I do live in southern arizona, so that might be a considering factor. Thanks in Advance, az_rat Quote Link to comment
datzenmike Posted March 24, 2019 Report Share Posted March 24, 2019 I would keep the phenolic? insulator if at all possible. Nissan thought it was needed for the stock carb although the Weber may not, I just don't know. If making gaskets get extra thick material. Don't forget to use Loc-Tite on the adapter studs. Quote Link to comment
Stoffregen Motorsports Posted March 25, 2019 Report Share Posted March 25, 2019 If I had my choice between a thin heat shield that was large enough to protect the radiant air from reaching the carb and a phenolic insulator, I'd rather have the heat shield. It wouldn't be difficult to make one from aluminum. I'd try that instead. Quote Link to comment
