720_potter Posted March 13, 2019 Report Share Posted March 13, 2019 Will a 2.2L valve cover fit a 2.4L napz engine, can't find a aluminum valve cover so I need to know if this will fit before I order one Much appreciated, Cameron potter 1 Quote Link to comment
datzenmike Posted March 13, 2019 Report Share Posted March 13, 2019 A Z22 aluminum valve cover (only used, I think, on the 720 truck) will fit the Z24 engine, yes. You will need to use the longer Z22 screws though, the Z24 screws are too short. 1 Quote Link to comment
720_potter Posted March 13, 2019 Author Report Share Posted March 13, 2019 Just now, datzenmike said: A Z22 aluminum valve cover (only used, I think, on the 720 truck) will fit the Z24 engine, yes. You will need to use the longer Z22 screws though, the Z24 screws are too short. OH HELL YEAH, thanks now I can make the engine bay even cleaner 1 Quote Link to comment
datzenmike Posted March 13, 2019 Report Share Posted March 13, 2019 Any bolt that fits will do just your old ones won't. You can buff that aluminum up to look like chrome. 1 Quote Link to comment
720_potter Posted March 13, 2019 Author Report Share Posted March 13, 2019 26 minutes ago, datzenmike said: Any bolt that fits will do just your old ones won't. You can buff that aluminum up to look like chrome. That's what my plan was since I have steel one that's been painted weird from the last owner 1 Quote Link to comment
datzenmike Posted March 13, 2019 Report Share Posted March 13, 2019 The '80 and up A10 and S110-200sx both had Z20 engines that may have also had the aluminum cover... not sure. The Z20 on the 720 didn't but the Z22 did.. 1 Quote Link to comment
720_potter Posted March 13, 2019 Author Report Share Posted March 13, 2019 Just now, datzenmike said: The '80 and up A10 and S110-200sx both had Z20 engines that may have also had the aluminum cover... not sure. The Z20 on the 720 didn't but the Z22 did.. Ight will look into that as well 1 Quote Link to comment
Charlie69 Posted March 13, 2019 Report Share Posted March 13, 2019 The cars mentioned above have the aluminum valve cover also. The cork gasket is for the aluminum valve cover. Also the aluminum valve cover bolts from an L motor are the same as the Z motor aluminum valve cover. 1 Quote Link to comment
720_potter Posted March 13, 2019 Author Report Share Posted March 13, 2019 1 hour ago, Charlie69 said: The cars mentioned above have the aluminum valve cover also. The cork gasket is for the aluminum valve cover. Also the aluminum valve cover bolts from an L motor are the same as the Z motor aluminum valve cover. Ight thanks 1 Quote Link to comment
