Derek 620 Posted March 10 Report Share Posted March 10 4 hours ago, EDM620 said: This is what the switch and wiring should look like. 3 green wires Is there a way to bypass a broken hazard switch ? Quote Link to comment
datzenmike Posted March 10 Report Share Posted March 10 Not really. The switch has two functions to prevent the turn and the 4 way from interfering with each other. 1/ in the off position the turn signals are run through the closed switch 2/ in the on position the turn signals are disconnected and all tail/front signal lights are connected to the emergency flasher unit. On my '64 dodge if the key was out of the ignition you could turn the 4 way on, turn the turn signal on, turn the wiper on and the arms would jerk up and down the glass with the 4 way. I think my 70 Dart would also. Quote Link to comment
