Angeldust720 Posted February 1, 2019 Report Share Posted February 1, 2019 So im thinking of putting st doors on my delux becuase the vinyl is starting to dryrot and im wondering if anyone has thought of doing that or is it just me Also wanting to wire the power windows if possible, tips? 1 Quote Link to comment
datzenmike Posted February 2, 2019 Report Share Posted February 2, 2019 The 720 doors are all the same. Electric window doors can only be used with electric windows. The inner skin is different as is the door card, though the outsides are the same. It may also have electric door locks. Sure would be easier if you had the dash harness with all the plugs on it. 1 Quote Link to comment
Charlie69 Posted February 2, 2019 Report Share Posted February 2, 2019 Mike is correct the ST electric doors inside skin is different then the non power doors, the outside of the doors are the same whether power or non power doors. I have 2 sets of power doors and also 2 wiring harnesses for the doors. Both harnesses are from 4x4 King Cabs as are the doors. One harness is for the TBI Z24I and one is for the carbureted Z24. I also have 1985 ST parts truck with non power doors and a 1984 ST builder truck with power windows door locks and moon roof. I am in Tolleson AZ which is SW Phoenix. 1 Quote Link to comment
Angeldust720 Posted February 3, 2019 Author Report Share Posted February 3, 2019 23 hours ago, Charlie69 said: Mike is correct the ST electric doors inside skin is different then the non power doors, the outside of the doors are the same whether power or non power doors. I have 2 sets of power doors and also 2 wiring harnesses for the doors. Both harnesses are from 4x4 King Cabs as are the doors. One harness is for the TBI Z24I and one is for the carbureted Z24. I also have 1985 ST parts truck with non power doors and a 1984 ST builder truck with power windows door locks and moon roof. I am in Tolleson AZ which is SW Phoenix. So if i get the wiring harness for the doors and the doors themselves, will they fit on the truck or are the power doors designed specifically for the ST? 1 Quote Link to comment
Charlie69 Posted February 3, 2019 Report Share Posted February 3, 2019 You need the complete ST doors with all the electronics, wiring, door panels with switches and the main uncut wiring harness. ST electric doors and door panels Quote Link to comment
Charlie69 Posted February 3, 2019 Report Share Posted February 3, 2019 Be easier to install after market power windows and cheaper. 1 Quote Link to comment
Charlie69 Posted February 3, 2019 Report Share Posted February 3, 2019 58 minutes ago, Angeldust720 said: So if i get the wiring harness for the doors and the doors themselves, will they fit on the truck or are the power doors designed specifically for the ST? Yes the doors are interchangeable. Quote Link to comment
Angeldust720 Posted February 4, 2019 Author Report Share Posted February 4, 2019 20 hours ago, Charlie69 said: Yes the doors are interchangeable. Ayy thanks i just looked today and theres a plastic peice covering the hole for the wiring to the doors, Will try to find doors in junkyard tomorow 1 Quote Link to comment
datzenmike Posted February 4, 2019 Report Share Posted February 4, 2019 I doubt the wiring is sitting there in the truck ready for the ST doors to be bolted on. You'll probably need the ST cab wire harness. This will include the fuse box with the missing electric windows fuse, and allow you to work the passenger side window from the driver's side switches. 1 Quote Link to comment
Angeldust720 Posted February 4, 2019 Author Report Share Posted February 4, 2019 22 minutes ago, datzenmike said: I doubt the wiring is sitting there in the truck ready for the ST doors to be bolted on. You'll probably need the ST cab wire harness. This will include the fuse box with the missing electric windows fuse, and allow you to work the passenger side window from the driver's side switches. If i take it to a car electrician in my town, do you think he can do it? Also my truck has lots of fuses from other trucks so i think i have a fuse for power windows, also for a clock but the fusebox cover says clock in white, i doubt it has one since i think its base trim idk tho, thoughts? 1 Quote Link to comment
datzenmike Posted February 4, 2019 Report Share Posted February 4, 2019 Yes you can wire it yourself. I made my own e windows for my 620 and used GM toggle switches (because they looked awesome and wer cheap and available) and could work the passenger side too. 2 Quote Link to comment
Charlie69 Posted February 4, 2019 Report Share Posted February 4, 2019 I would just pull the harness from the truck you get the doors from. Then you know the wiring is correct and you can do it yourself. 2 Quote Link to comment
