agouge888 Posted January 17, 2019 Report Share Posted January 17, 2019 1974 620...still trying to get fuel pumping properly. I’m changing the fuel pump and it has a thin gasket, but also has a 1/4” gasket too. Is that 1”4 spacer gasket supposed to be there between the fuel pump and the mounting surface? thanks, agouge888 Quote Link to comment
Ben_upde Posted January 17, 2019 Report Share Posted January 17, 2019 Yes. The spacer is usually a plastic material to help prevent heat transfer from the head to the pump/fuel. There will be a gasket on both sides of the spacer as well so a total of 2 gaskets are needed. Quote Link to comment
datzenmike Posted January 17, 2019 Report Share Posted January 17, 2019 Without that 1/4" plastic spacer the pump arm will grind on the cam eccentric. Quote Link to comment
agouge888 Posted January 17, 2019 Author Report Share Posted January 17, 2019 Thanks for the quick replies fellas. agouge888 Quote Link to comment
