bbqbill Posted September 30, 2018 Report Share Posted September 30, 2018 I have replaced a lot of my rusted out floors, would like to get new body mounts, I can’t find any new/ reproduction ones . Any ideas , will some from a different model work? I have a 76 620 Quote Link to comment
Crashtd420 Posted September 30, 2018 Report Share Posted September 30, 2018 Try typing in cab mount instead of body mount... there are 2 sets on ebay.... but it's only the rubber.... I used the universal body mounts from energy suspension on my 521, worked out real good.... you still may need new bolts but they give you the metal sleeves and some washers.... I did have to get some different washers for inside the cab... the washer supplied was bigger than the recess on the floor.... just note the spacing before you pull everything apart.... the energy suspension has 2 different thickness to the rubber ... I think I put the bigger one between the body and the frame.... I assumed by the picture the plate is the frame, not the body.... 1 Quote Link to comment
Jayroc Posted October 1, 2018 Report Share Posted October 1, 2018 I'll check in ghe shop tomorrow. I have the number for the engery bushibgs i used on my 76 Quote Link to comment
bbqbill Posted October 1, 2018 Author Report Share Posted October 1, 2018 Thanks for the help, l will check them out. I have all the washers the rudder mounts are just dryed and cracking. I would appreciate the number thanks Quote Link to comment
Jayroc Posted October 1, 2018 Report Share Posted October 1, 2018 9.4101G engery suspension 1 Quote Link to comment
mikecaleb Posted October 2, 2018 Report Share Posted October 2, 2018 I Used one of the Energy performance kits for my 86 Hardbody. the O.D. of the sleeve was a tad bit bigger than the holes for the mounts under the front radiator support. So I went out and bought me a step drill bit big enough and took my time widening out the holes. ( its wasn't a big enough difference to where it would affect structural integrity IMO) They fit perfect now and i couldn't be happier with the difference that they made. I was sick and tired of hearing the truck squeak 24/7. Quote Link to comment
