bubba_doc Posted March 2, 2018 Report Share Posted March 2, 2018 Where is the fuel pump relay on a 1985 nissan king cab 4x4? I need to try and wire up an addition pump i am putting inline to provide increase pressure for a blow through carb turbo application. Quote Link to comment
datzenmike Posted March 2, 2018 Report Share Posted March 2, 2018 It's beside the glove box, above the passenger side kick panel, just out of sight. There will be a smaller brown or blue electric choke heater just below it. The fuel pump relay is larger. Here... https://axleaddict.com/auto-repair/The-Datsun-and-Nissan-Pickup-Fuel-Pump-Relay-What-the-Haynes-Automotive-Repair-Manual-Wont-Tell-You 1 Quote Link to comment
bubba_doc Posted March 2, 2018 Author Report Share Posted March 2, 2018 DM, that was so helpful...... I am speechless. I speak blessings upon you and your family for many generations to come. 2 Quote Link to comment
datzenmike Posted March 2, 2018 Report Share Posted March 2, 2018 You are most welcome. 1 Quote Link to comment
KELMO Posted March 2, 2018 Report Share Posted March 2, 2018 Just in case you need to replace it, the Nissan part # is 28545-89900. You would have to call a dealership to see if they are still available. Quote Link to comment
weldingrod Posted March 13, 2018 Report Share Posted March 13, 2018 Anybody know where I can find a 1985 720 driver's side rear signal light and a return fuel line check valve? With a shed full of parts, guess which ones I don't have? Quote Link to comment
datzenmike Posted March 13, 2018 Report Share Posted March 13, 2018 Post a want ad... http://community.ratsun.net/classifieds/category/3-datsun-parts/?sort_key=date_added&sort_order=desc... buying and selling have to be done there. The tail light reflectors from Oct. '83 and up build dates should interchange through to the end of the 720, even though the beds changed for '85. 2wd and 4x4 lenses are different, probably something cosmetic, and should fit but won't match side to side. Quote Link to comment
weldingrod Posted May 9, 2018 Report Share Posted May 9, 2018 I found a brass check valve at a marine supply store for $10. Canadian, that is. Quote Link to comment
