Button Posted December 14, 2017 Report Share Posted December 14, 2017 Hey guys, I purchased a Quickor front sway bar about 3 years ago and I am finally getting around to install it and I, for the life of me, can not get it to fit. So the bar has the big dip in it to clear the engine but I can't tell if the middle of the bar should be above or below the plate that sticks out in front of the front cross member. I can get it above the plate but I can't rotate it up enough to attach the end links with out the bar hitting the crossmember. If I go below the crossmember then I am no where close to making it fit. Am I missing something obvious? Does anyone have any photos of how others are mounted? I have searched around some but I can't find much besides people that have made standoffs and attached the sway bar below the lower control arms. Quote Link to comment
carterb Posted December 14, 2017 Report Share Posted December 14, 2017 Here are some installation pictures of the suspension techniques bar. I assume they are similar. 1 Quote Link to comment
Noflers Posted December 14, 2017 Report Share Posted December 14, 2017 http://imgur.com/a/KeOQg Here's more, hope they help. Quote Link to comment
mrbigtanker Posted December 15, 2017 Report Share Posted December 15, 2017 That looks like a rear sway bar. Quote Link to comment
datzenmike Posted December 15, 2017 Report Share Posted December 15, 2017 Front cross member is on backwards? 1 Quote Link to comment
carterb Posted December 15, 2017 Report Share Posted December 15, 2017 custom sway bar for front sump motor w/ flipped crossmember? --carter 1 Quote Link to comment
datzenmike Posted December 15, 2017 Report Share Posted December 15, 2017 ... can only assume so. However... Hey guys I am trying to get a my L20 rebuild wrapped up and installed with a 5 speed into my 510 but I have a few questions first. Quote Link to comment
Noflers Posted December 15, 2017 Report Share Posted December 15, 2017 Yes this is a modified crossmember with a custom sway bar, they were meant to show the attachment points, end links, etc. Quote Link to comment
Button Posted December 19, 2017 Author Report Share Posted December 19, 2017 Thank you guys for the input. CarterB those images were very helpful. Based on some other info I found I believe they accidentally set me a swaybar for an SR set up instead of a standard 510 bar. I will email Quickor and see if they can send me the correct one. Quote Link to comment
