Sign in to follow this
610StaWag
Headliner
Headliner re-install questions
I am putting the headliner back in. I lost the baggie that I had put the fittings into. I do not find I have any screws or bolts that appear to fit correctly. To take this photo, I have temporarily held the top cross piece in place with partially screwed in crude over sized screws.
Question #1 , What type and size of attachment fittings go here (the red arrows above)?
Question #2, I don’t have a photo I took before I took the headliner out and I am a bit perplexed as to the re-assembly. From the glue marks on the metal I assume the headliner edge glues to this crosspiece AND this crosspiece then goes on top of the headliner. I just don’t remember what this looked like. Is this metal edge supposed to show? Is there an interior appearance trim piece that is supposed to cover this piece? Or are the exposed heads of the attachment fittings supposed to show?
Question #3, Is it best to re-install the headliner at the front windshield first and then work back to the rear?
37706282224_d8e53fd085_b.jpgHeadliner question - 1 by Donald Broz, on Flickr
Share this post
Link to post
Ideally the headliner goes on before the glass goes in. I think I would start at the front. You do have the bowes for it?
Share this post
Link to post
Yes, I have the bows. Both bows and holes were numbered per Ratsun advice.
The car appears 100% stock with unaltered/replaced windshield. The head liner was glued to the underside of the curved metal piece.
Most important to me now is that I need to know how to attach the curved metal piece that has the seven holes. I could make a trim piece to cover screws (?), bolts (?), other (?).
It seemed to me that starting in front made sense. Thanks for the second.
Share this post
Link to post
Thanks datzenmike. I just looked at the car again and I see what you mean about the piece being put in under the windshield. On closer inspection, I noticed that, yes, that piece should have been put between the body and the windshield and it wasn't. So I'll just have to make do; I'm not in a position to afford to replace the windshield. What are my alternative choices to attach that curved piece with the seven holes?
Share this post
Link to post
I apologize. No problem here. I see that the headliner wraps over the curved metal piece. The screws are hidden under the headliner. So simple, I get it now.
Share this post
Link to post
Start at front and use that strip across the back to evenly pull the headliner taught. Can the liner be poked under the rubber at the front with a butter knife or something very blunt?
Share this post
Link to post
Thanks,
Yes. The rubber piece slips off. I will be able to [wrap around and] glue the front edge of the headliner to the sheet metal part and then slide on the the rubber piece.on.
What did you mean by: ".use that strip across the back to evenly pull the headliner taught.." ?
Share this post
Link to post
I thought the rear had a strip with holes for screws to hold the liner? Maybe thinking of my 710 sedan. The goon doesn't have glass to tuck the liner under.
Ahhh I see the problem. The picture is of the front.
Share this post
Link to post
I just took off the plastic cover with a light housing from a goon that covers the hinge aera in the back. I sent to a member here.
Don't know if this will help. There are several small screws that hold it on.
Now after looking I see yours is a 610, the stuff I took off was from a 510 sorry.
Share this post
Link to post
I have a 710. I don't know what's up under it, afraid to remove and not get back on right. I don't think it looks like that though. I was flirting with the idea of just getting some black fabric and just gluing it onto what's there. I have several small tears and holes form loading cargo to cover.
Share this post
Link to post
There is a tool that looks like a brake spring tool except it has a ball on the tip. Its designed to break the rubber seal from the windshield It would also push the headliner into the rubber weatherstripping. I found it on the LMC truck website
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
