Floor temp light
Scgreen620
I have a 78 620 it has a floor temp dummy light, problem is now it's staying on even if the truck is off has anyone had this problem ? It was fine before I'm just concerned it might kill the battery if I don't pay attention to it...
I have to tap it in order to turn off when the car is off
  • Replies 8
Odd, I would expect this to be activated only when the key is on.
Most fires started by an over-heated catalytic converter are after the car is shut off and the static heat is trapped without airflow.
Seems like that's when you'd want it to work the most.
Sidenote: I once had a fire start under my truck due to being lowered and parking in taller grass lol.
