620 521 Sway bars, install - available again !
Wanted to put this out there Futofab got them built again I am told through Dave .(I remember my cust buying on ebay turn six years back they were rare ), my customer scooped up a set and I installed on the nice 1974 620 with wilwoods (we did not paint orange they came that color ).Rear was a little work .You need truck at ride height with axle on stands or ramps need to drill frame and install U bolts thru frame pretty easy then adjust on axle to clear shocks exhaust and had to release brake line at top of diff clamp when jacked up would hit there. Front is a one inch bar went on easy had to wallow holes a little bit towards inside on bushing brackets .
Also has poly upper a arm bushings from Blue Hands .
I usually post my shop work in off topics , at this time doing a 521 sr20de swap, will get back on after 1984 Mitsu 4x4/Dodge ram gets done for my son up north Tahoe.IMAG0029_1.jpgIMAG0040_1.jpgIMAG0042.jpg
  • Replies 3
  • 1 year later...
