Hitachi Fail in 720
Humboldt
  • Replies 69
if you clean the jets out but forget blow out the fuel passages will cause it to run like shit.
check your valves too. if they are too tight, it wont breathe right
I advise against webers, seems like they are for lazy people. :poke:
I couldn't tell you the proper terminology haha but...
It the top is off and you slid the jets up, there should be holes in the wall where the jet slides in.
You need a coil with an impedance of one ohm, or just under. The points coil will be 1.5 and needs a ballast resistor in line to double the impedance to 3 ohms. If used with a newer EI set up it will draw toooo much power through it and over heat the coil.
I have too (two) many projects.
The 72 goon has a matchbox dizzy scabbed off a donor yellow 80 720 king cab (now in the junk yard). It's coli reads 9.9k primary, 1.4 secondary. (with no external resistor) I'm reading spec. to be primary8.2 - 12.4k ohms and secondary .84 - 1.2 ohms, so it is in range.  I fired it up yesterday with a hose to a can of gas using my newly cut key. There was some smokeage coming off the exhaust manifold, which I tightened down later. Still not getting gas to suck up from the tank. I blew on the line that comes from the tank, before the fuel filter and it didn't seem to be blocked. Is their some juju I need to know  about the  evaporative tank, or do I need to try to blow out that line with compreessed air?
:poop: Then I couldn't get the ignition to shut off. Key rotated to no avail.
Meanwhile, my remaining  white 1980 720 coil also reads within range: 10.7k primary, 1.1 secondary (no external resistor) Spark plug wires all read 5.5 - 6k so they are fine (less than 30k). Spark plug gaps fine. But I still can't get id to idle smoothly. It sounds like it has a hot cam then dies. I'm back to thinking that Hitachi has gotta go.
  • 3 weeks later...
Good idea...not sure what the previous owner intended on my car back in the days but my carb was acting up and compressed air to the line worked for awhile then fuel starved again so i took out fuel tank and clean inside but then I saw silicon blocking the fuel inlet. You may want to check ur tank anyway. Not hard to take out
Blew out fuel line with Harbor Freight pancake compressor ($39.99). Getting gas now, yay!. One wrinkle: my ground wire to alternator was disconnected and the motor wouldn't shut off! Had to choke it to death.  Replacing valve cover gasket and doing valve adjust now. Then I'll reinstall the passenger's side door lock I removed to get key code for cutting a key to replace missing key. Getting cllose to roadworthy vehicle.
