1972 510 electrical problem
  • Replies 4
Replace all the fuses to rule them out. Buy a box at harbor freight for $8 and you'll be set for the life of the car. Don't chase stuff around for hours to later find it was only a fuse. Fusible links blown? Grounds? The fat solid white wire is constant power into the box, and the ignition switch sends power to the box as well when it's in certain positions. Photobucket is conveniently not working or I'd post a wiring diagram. Just search for it.
