cheetah79857985 Posted December 9, 2008 Author Report Share Posted December 9, 2008 If I understand my research correctly, checking and replacing the valve lash is going to be a huge project (for me, I've gone as far as I can with the knowledge I have. I don't know about cams, how to get the cover off, much of anything about pistons.) that don't have the appropriate time, tools, or even surroundings (I live in an apartment complex) to undertake. I dont understand the timing advance either. Do I need to buy a timing light (those gun-looking things) and attach it to one of the vacuum hoses? I do appreciate all the help that's been given. And BTW, letting the engine warmup for five to ten minutes did give me a smoother ride, but the problem of the engine "jumping" was still there. Quote Link to comment
bonvo Posted December 10, 2008 Report Share Posted December 10, 2008 a timing light connects to the number 1 plug wire and the battery positive and negitive its basicly a strobe light that goes off when number 1 fires to check the valve lash your going to need a set of fealer gadges and a 10mm scoket 5 inch extention and a ratchet look up how to do it (if you have a factory service manuel that would be perfect) you start by removing the 6 valve cover bolts to remove the valve cover (pictured here circled in green) since i havent adjusted the valves in mine yet i cant tell you any more but this is a good start i hope it helps Quote Link to comment
datzenmike Posted December 10, 2008 Report Share Posted December 10, 2008 (edited) Go here: http://www.nwde.org/extras/forum/forum_posts.asp?TID=3582 .. go down about half way first page. Look for 'more L series info' : Mklots valve clearance adjustment. All you need is a couple of wrenches and a set of feeler gauges. $10- $20 to buy, but a mechanic will charge you an hour's labor to do this. Don't pay for his house and car payments!!! Edited December 10, 2008 by datzenmike Quote Link to comment
cheetah79857985 Posted December 11, 2008 Author Report Share Posted December 11, 2008 Thanks you two, that looks tons more helpful than what I pulled up. Quote Link to comment
racerx Posted December 16, 2008 Report Share Posted December 16, 2008 It helps when you have a chiltojn's or a Haynes manual.. Quote Link to comment
