roadkill2525
'78 280Z 2+2
Just picked this up today, needs a few things done before using on a regular basis. Found a factory service manual on Amazon and it's on the way.
17309960_10209562732599935_8862940426572
Share this post
Link to post
Was $4300, has had a repaint in the same color (301 Brown Metallic). Short term plan is to fix things like the locks and linkage to make it useful for a daily driver while I get some work done on the B210, the long term is to make a Grand Tourer style car.
Share this post
Link to post
thats a wonderful plan not enough people do. i dailied mine for a year nd a half with no locks, just took my steering wheel and shifter with me everywhere i went lol
Share this post
Link to post
How is the interior of your car? I know of some nice black door panels for a 2+2
Back seat in OK condition. I can get more details if you're interested.
You want spare glass? Its unique to the 2+2 model.
Share this post
Link to post
Got a shipment from Rockauto and Zcardepot, need to send the Kia Sephia/Spectra clutch master cylinder back though. Rockauto sent a Exedy MC559 instead of the Exedy SC559.
Share this post
Link to post
are you replacing the clutch slave cylinder as well? If the slave is weak, it can blow out the seals soon with a brand new master cylinder.
Share this post
Link to post
Yes, waiting on the slave cylinder because Rockauto sent a clutch master cylinder for a Kia (part #MC559) instead of the clutch slave cylinder (part #SC559).
Share this post
Link to post
Well I'm done with it, tired of chasing electrical problems with the headlights. Good Sylvania headlights from the B210, new fusible links, fuses, working headlight and dimmer switches but still have bright/dim or dim/off combination. Got the turn signals working with a new relay but not happy if only relegated to driving during the day.
Still need to replace the clutch master and slave cylinders. Also need to look at parts for the door locks.
Share this post
Link to post
"Hope it ... helps"
                  - Dr. Zed
Share this post
Link to post
The turn signal just needed a new flasher relay, the original Niles came out and the new one went in with the original bracket.
This is starting to be like the '86 Camaro IROC, dumping money into it just to get it running right.
Share this post
Link to post
My dad replaced the Exedy slave cylinder with one from the parts store while I was at work, aside from adjustments to the pedal  the clutch works.
While pricing out a new exhaust system for the Z we found out its a federal model.
What would be needed to be done to the engine if I wanted to put a header on?
Share this post
Link to post
Ran it through smog testing and it failed, after having it checked out by a mechanic there's a laundry list of problems. I know a engine rebuild was in it's future but was hoping it would get by one smog test, any recommendations on engine building services in the North Bay aside from Rebello Racing in Antioch.
Found bad intake manifold gasket
Found bad EGR gasket
AFM resistance not to manufacture spec's - tampered with
Injector terminals and connectors corroded
Found fuel pressure is 35psi at idle and with regulator vacuum source disconnected 43psi
AFM hose bad and in need of clamp
Compression test 1-5= 150psi, 6=110 Average compression is 180psi
Leakage test 1-3=30%, 4-5=20%, 6=70%
Recommend complete engine restoration
Share this post
Link to post
Consider selling that one and buy one that's 75 and older, then u will not have to deal with smog.
Share this post
Link to post
Are you going to be bankrolling this?
Share this post
Link to post
No, just trying to save u some heartache, been der. You had several cars that you dump money into and just don't want see you go through again.
Share this post
Link to post
Well my name isn't on the title and to simply throw around money for another isn't a option.
Your answer might as well be one from the Camaro forums I was on when I was driving mine, never giving anything helpful but just posting to seem relevant.
Share this post
Link to post
Looking at replacing the off brand aftermarket stereo head unit, don't know if the speakers were replaced.
Planning on using Pioneer but recommendations for speakers and head unit.
Share this post
Link to post
