DogoX Posted October 22, 2016 Report Share Posted October 22, 2016 Hello guys, finally decide to start my Rotary The beginning of the car a complete factory 1200, I started by removing the factory A12 to make room for the Mazda 13B Turbo. It will be injected using a Microtech LT10x4, a complete ProJay intake set up with 8 1600 injectors. Front suspension will come from the guys at MadDat and their 13B kit, also using their adjustable Lowe control arm. Struts will be modify and use the T3 coilover system and their camber plate. The front brake has become an issue, this is my hurdle as of today! The rear end will also be swap to a Ford 8.8, will eliminate the c-clip and change the end plata to a Big Ford. Axel will come from Strange Engineering and a set of Wilwood brakes to be able to keep the emergency brake. The wheels are RC Components 15x10 single beadlock using Mickey Thompson 26x12 tires Rear suspension will consist of a custom ladder bar system and a set of QA1 single adjustable coilover 2 Quote Link to comment
DogoX Posted October 22, 2016 Author Report Share Posted October 22, 2016 Front brakes are the hurdle, I follow the advice of a friend and bought a set of Wilwood brake kit and found out they don't fit. Now have to tinker around to see what I can come up with. Originally was going to use the Aerospace kit but I personally had multiple rotors warp. While they are great on the Drag strip they don't take the regular driving heat exchange to well. Thanks for looking, any suggestion or advice are welcome Quote Link to comment
difrangia Posted October 22, 2016 Report Share Posted October 22, 2016 Damn, that's a beautiful little car !! That shop is pretty snappy looking too !! Steve Quote Link to comment
DogoX Posted October 22, 2016 Author Report Share Posted October 22, 2016 Damn, that's a beautiful little car !! That shop is pretty snappy looking too !! Steve Thanks, got to keep the garage clean winter is just around the corner and the wife car, you know got to be inside or else parts will be flying around Quote Link to comment
tr8er Posted October 22, 2016 Report Share Posted October 22, 2016 Damn that's a pretty beautiful interior. Quote Link to comment
