Droski Posted October 20, 2016 Report Share Posted October 20, 2016 hello gang im currently running a Nikki Carburetor on my j13 engine for my 1966 520 pickup i was wondering if there are any better carburetor options that i could simply bolt on ive heard talk about webers being good replacement options is it possible to put 620 or 720 carbs on a j13 engine? Quote Link to comment
datsunaholic Posted October 20, 2016 Report Share Posted October 20, 2016 Webers will require an adaptor unless you can find a hens-tooth rare 34DFT. The bolt pattern is the same as the later Hitachis, but there is some concern with valve cover clearance since the Nikki carb is quite a bit smaller. I've seen 32/36 DGV Webers on J13s, it's a little bit large and it does require an adaptor but they do work. Quote Link to comment
wayno Posted December 15, 2016 Report Share Posted December 15, 2016 Are you talking about this Redline-Weber Carburetor? Quote Link to comment
datzenmike Posted December 16, 2016 Report Share Posted December 16, 2016 hello gang im currently running a Nikki Carburetor on my j13 engine for my 1966 520 pickup i was wondering if there are any better carburetor options that i could simply bolt on ive heard talk about webers being good replacement options is it possible to put 620 or 720 carbs on a j13 engine? Rebuild yours, by rebuild I really mean take apart and clean it. There are few parts that wear out and dirt and maladjustment are the cause of most problems. 1 Quote Link to comment
