Idle problem on 1985 nissan pickup
Blas671
  • Replies 7
Does it have a round 6 wire connector at the back or a smaller connector with just two wires?
Going to guess it's the former. It has to have all the wires and sensors connected and working including an O2 sensor for proper mixture feedback. This carbs mixture and idle are governed by an ECU under the pass side seat that constantly adjust the carb primary jet. If there is a failure in the system it will try to go into a limp home mode or over rich condition to protect the engine from a damaging over lean mixture. It will run poorly and give terrible mileage.
Please don't tell me you have a weber now.
1985 should be electronic carb with 6 wire connector unless a 4 wheel drive then it could throttle body injected.  This all depends on if it is stock.  spray some carb cleaner or starting fluid around the base of the carb where it bolts to the intake manifold while it is running.  if the engine gains RPM while spraying it has a base gasket leak causing a vacuum leak which will not let engine idle.  Also check for other vacuum leaks.  EGR is notorious for vacuum leaks on the Z24.
