DatsuNissanLove Posted February 3, 2017 Report Share Posted February 3, 2017 Yes don't pay mechanics dude.. I took mine to get aligned cuz my back went out and no damn space at my house to work n the truck still swings to the left like beyonce... especially wen I hit the breaks Quote Link to comment
Datfish Posted February 25, 2017 Report Share Posted February 25, 2017 Lol...Beyonce That sounds like brakes not being even tho. Quote Link to comment
datzenmike Posted February 25, 2017 Report Share Posted February 25, 2017 n the truck still swings to the left like beyonce... especially wen I hit the breaks Not the alignment. Adjust your front and rear drums. Quote Link to comment
DatsuNissanLove Posted February 25, 2017 Report Share Posted February 25, 2017 Will do.. but it does it even wen I don't press da breaks.. Quote Link to comment
datzenmike Posted February 25, 2017 Report Share Posted February 25, 2017 Tension rod bushings worn out. Those are those long rods mounted to the very front of the frame and going back to the outer ends of the lower control arms. They support the LCA in place and prevent them being forced backwards if the wheel hits an obstruction. Also when the brakes are applied they transmit the stopping action to the frame. Without the tension rods the LCA would move back and forth with the wheel if you hit something or brake. If they are bent or the bushing damaged, braking can force the wheel way out of alignment and cause the vehicle to veer when braking Quote Link to comment
