edekalil Posted September 6, 2016 Report Share Posted September 6, 2016 Got to improvise something for the tube that go's in the drivers side of the motor that connects to the Pcv valve on the intake manifold. That is the only thing I have to work out befor I can go forward to crank her up. It's a 1600 in my goon. Quote Link to comment
datzenmike Posted September 6, 2016 Report Share Posted September 6, 2016 It's a press in (slightly tapered) tube. The L20B one exits upward and won't work. Quote Link to comment
edekalil Posted September 6, 2016 Author Report Share Posted September 6, 2016 It's a press in (slightly tapered) tube. The L20B one exits upward and won't work. That's the one Mike, I have it some where here just hidden under some stuff. I did find the one from the l20b. I will just have to unearth everything out of the blue 510 and it might be in there. I thought it might be close to the motor from when I had taken it out but no. I plan to get the wagon fired up this week but I have to figure this out first. I knew I should have gotten the one off EBay a while back when I had the chance. Quote Link to comment
edekalil Posted September 7, 2016 Author Report Share Posted September 7, 2016 Mike or anyone who see's this how would one go about taking a tube like this off of a 1600 motor sitting around? Quote Link to comment
racerx Posted September 7, 2016 Report Share Posted September 7, 2016 Measure hole and get a thin pipe from home depot and found it in. Did this many moons ago and has not come off. Quote Link to comment
edekalil Posted September 7, 2016 Author Report Share Posted September 7, 2016 Thanks I will give it a shot Quote Link to comment
datzenmike Posted September 7, 2016 Report Share Posted September 7, 2016 It's just pushed in and tapped down with a hammer? Just wiggle loose. An L20B one will likely work if you cut the engine end off and weld something onto it. The L20B pipe exits upward, bends to the rear and then bends around the exhaust manifold near the fire wall. Won't work on an L16/18. Quote Link to comment
