datsun12 Posted May 28, 2016 Report Share Posted May 28, 2016 I have a l20b motor and I want to install an electric fan but I have little clearance due to the waterpump having a clutch fan. My question is, is there any waterpump that I can use that only has a pulley? Thanks for the help Quote Link to comment
datzenmike Posted May 28, 2016 Report Share Posted May 28, 2016 Most 521/510/620 L16 were just a pump with attached fan. L18s were about the same... we only got the L18 on mostly '74 model cars and truck. 610/710/620 Most L20Bs received the clutch fan to save energy and improve mileage. The '80 720 only had the clutch fan with optional air conditioning. #21010-21026 same as the 510/521/521/610/710 with L16 or L18. You'll have to confirm Nissan part number 21010-21026, but it seems to check out. I just carefully cut the clutch fan off. Just stay away from where the pulley is pressed onto the shaft. Leave 1/8" . Quote Link to comment
INDY510 Posted May 28, 2016 Report Share Posted May 28, 2016 I did this mod to fit a 3" thick radiator and electric fans: http://community.ratsun.net/topic/15038-l-motor-electric-fan-water-pump-mod/ .... that gives you a little more room than just a L16 pump, without a fan 1 Quote Link to comment
Doctor510 Posted May 28, 2016 Report Share Posted May 28, 2016 Mount it in Front of the radiator 1 Quote Link to comment
Loryde520 Posted May 29, 2016 Report Share Posted May 29, 2016 Why do you want an electric fan? I have mine mounted between the grille and radiator. I only have one brcause of clearance issues with an L20B in my 520. I would prefer a clutch fan but can't. 1 Quote Link to comment
