521 Carb Problems
V521V
Hello Ratsun,
hit a wall and i know its something easy to fix. Here's my problem.. truck will only run off alternative fuel when i dump gas down carb. It is getting plenty of fuel delivery to the carb. I can take the fuel inlet off and it squirts lots of fuel. I put a brand new weber dgv on and got the same results as with the stock hitachi. Pulling out my hair because i know the problem is simple and i just dumped ~$3 bones on a carb i didn't need. O well i have a spare now. I have adjusted valve lash to correct gaping. Going to check timing tonight. Anything i should look for? Im thinking vacuum maybe?
Thanks,
v521v
  • Replies 8
I just relined the tank so Im assuming i just got a bad batch of gas. It is an older local station and i might have got gas after they churned up the crud from the bottom of there tanks. Not sure, but its got good fuel now. Thanks again for the advice.
