antiextreme Posted March 7, 2016 Report Share Posted March 7, 2016 I would like to fit a fuel pressure gauge to my new Weber 36/38. Saw a guy in another post that mounted his opposite the fuel inlet on the front, which is what I did (see picture). I'm not getting any reading. Is this not a good spot, or could the gauge be bad? It is just a cheap Mr. Gasket. Quote Link to comment
banzai510(hainz) Posted March 7, 2016 Report Share Posted March 7, 2016 Why you want a gauge????? just run stock fuel pump call it good. 2 Quote Link to comment
antiextreme Posted March 7, 2016 Author Report Share Posted March 7, 2016 Is the stock pump going to supply about 3 pounds of pressure? The instructions that came with my Weber were pretty specific to try to keep pressure around that level. 1 Quote Link to comment
datzenmike Posted March 7, 2016 Report Share Posted March 7, 2016 Stock pump 2.8 to 3.4 PSI output. Just right and fine on a new weber. Take the gauge off and it probably needs drilling out so the fuel can reach the gauge. Shitty location, needs a fitting to tilt the gauge up. Gauge is kind of useless as you can't read it while driving. Like hainz says the stock pumps are fine and the gauge doesn't tell you much. 2 Quote Link to comment
banzai510(hainz) Posted March 7, 2016 Report Share Posted March 7, 2016 I run stock pumps the last 27years of Datsun ownership with 3 510s with carbs. No proplem with a weber DGV. I have a another 510 with a low pressure pump but has a regulator(Dial type). But no gauge. 1 Quote Link to comment
antiextreme Posted March 8, 2016 Author Report Share Posted March 8, 2016 Cool, thanks guys. I'll probably yank it off tomorrow. Quote Link to comment
Doctor510 Posted March 8, 2016 Report Share Posted March 8, 2016 Is the stock pump going to supply about 3 pounds of pressure? The instructions that came with my Weber were pretty specific to try to keep pressure around that level. I have run all my L series 4 cyl Weber's w/o a gauge or a regulator, this is over a 15 yr period. BTW, there is no such thing as a 36/38 Weber carb, 32/36, 38/38 are good numbers. 1 Quote Link to comment
