jalexquijano Posted February 24, 2016 Report Share Posted February 24, 2016 I have read somewhere that the MR. Gasket 9748 Glass Fuel Filter which you place in the engine bay is somelike flow restrictive. Is this really true? Should i consider swapping to a Fram G3 plastic clear filter? Anyone??? Quote Link to comment
DanielC Posted February 24, 2016 Report Share Posted February 24, 2016 No. In almost every case of some after market part, the quality of a original Datsun (Nissan) part is better, and often cheaper. I can get fuel filters for my 1970 521 at Nissan. Probably fuel filters for your 240 Z are at Nissan also. 1 Quote Link to comment
jalexquijano Posted February 24, 2016 Author Report Share Posted February 24, 2016 This is correct! Which fuel filter is then recommended for a 1972 240z free of flow restriction? 1 Quote Link to comment
jalexquijano Posted February 24, 2016 Author Report Share Posted February 24, 2016 Do you need to put an additional fuel filter next to the airtex 8012s fuel pump? Will this extend the life of the pump. I thought this pump had its own Steel fuel filter? 1 Quote Link to comment
KoHeartsGPA Posted February 26, 2016 Report Share Posted February 26, 2016 I have two inline filters with that replacement inner mesh, one is before the fuel pump and the other one right before the carb, that one is glass so that I can see the gas flow, no issues. Quote Link to comment
jalexquijano Posted February 26, 2016 Author Report Share Posted February 26, 2016 Measured the fuel pressure at the rear su carb and it was pushing 5 to 5.3 PSI with no overflooding on the float valves. I guess i will need a regulator for Airtex 8012s electric fuel pump (5 to 9 psi). Which one is recommended? Quote Link to comment
docbainey Posted February 26, 2016 Report Share Posted February 26, 2016 This site should answer any question you might have about SUshttp://www.zcarz.us/technicalinformationpagecarburation.htm Quote Link to comment
