SRSANDS Posted October 12, 2008 Report Share Posted October 12, 2008 On my L16 motor where the upper radiator hose connects the the water inlet there is another little threaded fitting that I have capped off currently. The cap is begining to swell and get ready to burst due to the pressure of the hot coolant. Can someone tell me where this connection goes and whats it purpose. I was thinking it may connect the another fiting I ave capped of at the base of the carb on the mani but im not sure. :confused: If you can send me a pic or let me know Quote Link to comment
SRSANDS Posted October 19, 2008 Author Report Share Posted October 19, 2008 Ok so I discovered exactly where these connections go with a hard line I had in my parts tub......now can some one tell me the pros and cons of just capping these points off or should I connect it all back up?? Quote Link to comment
datzenmike Posted October 19, 2008 Report Share Posted October 19, 2008 I would run with them hooked up. Warm water will flow through the intake to warm the air. This is especially beneficial during the winter and increases the engine's efficiency and improves drive ability. The hose from the thermostat housing is even more important. It pulls hot water past the thermostat. Without it the engine will heat up but there will be a delay in the thermostat opening because the cooler water around it isn't moving. Quote Link to comment
SRSANDS Posted October 19, 2008 Author Report Share Posted October 19, 2008 Thanks for the advice.....I will hook it up again even though its probablly going to be a pain to get the hose shaped like a C:) Quote Link to comment
dat521gatherer Posted October 19, 2008 Report Share Posted October 19, 2008 heres what i do. run one hose from the water neck on the side of the timing cover to the intake manifold. thus bypassing the thermostat t connection, meaning no ugly metal tube. about half didn't have the thermostat t anyway, i think those are the older l16's. now you can plug the thermostat hole or if your really cool like me you buy the corrector adapter and run your aftermarket tripple mini gauge with water temp to that hole thus having the original water temp and a after market one. :cool: Quote Link to comment
SRSANDS Posted October 19, 2008 Author Report Share Posted October 19, 2008 Thanks for the idea.....any pics? Quote Link to comment
banzai510(hainz) Posted October 19, 2008 Report Share Posted October 19, 2008 there were 2 types(a hot water line with a spout and 1 that went straight to the intake manifold) 1 with a bypass as you mention to the hot water line to intake and one that DID NOT have this. if you dont have the hot water line spout to the lower stat housing just maybe drill a 1/8 hole in the stat and that will be the bypass needed. save those water lines and lower stat housings. I like the ones with no holes if sidedraft cars will be used Quote Link to comment
zed Posted October 27, 2008 Report Share Posted October 27, 2008 Agree with Mike - don't run it without intake mani heater line. I blocked off mine, thinking it's hot enough where I live not to need it. Wrong - truck took forever to warm up, mileage was worse. The raw gas will probably wash oil off cyl walls too - result in faster bore wear. Quote Link to comment
SRSANDS Posted October 29, 2008 Author Report Share Posted October 29, 2008 Thanks definatley going to hook it back up.......is that hose shape like a C still available or what do I replace it with?????? Quote Link to comment
