Charlie69 Posted October 26, 2015 Report Share Posted October 26, 2015 I purchased my Weber for my 86 King Cab 720 from Pierce Manifolds. I have been buying Webers and Weber parts from them for over 30 years. Good people. Quote Link to comment
daniel5on Posted October 26, 2015 Author Report Share Posted October 26, 2015 I purchased my Weber for my 86 King Cab 720 from Pierce Manifolds. I have been buying Webers and Weber parts from them for over 30 years. Good people. I will check them out, thanks for the tip! 1 Quote Link to comment
datzenmike Posted October 27, 2015 Report Share Posted October 27, 2015 The idle mixture screw on the '84 is sealed at the factory and cannot normally be adjusted by the owner. 1 Quote Link to comment
Charlie69 Posted October 27, 2015 Report Share Posted October 27, 2015 The idle mixture screw on the '84 is sealed at the factory and cannot normally be adjusted by the owner. More reason to install a Weber! Quote Link to comment
datzenmike Posted October 27, 2015 Report Share Posted October 27, 2015 But an easy fix. Drill 1/8" hole in aluminum plug. Screw in wood screw and plug pops out so you can get at the adjustment. Not a good idea if you have emissions testing unless you cover it up again. 1 Quote Link to comment
daniel5on Posted November 2, 2015 Author Report Share Posted November 2, 2015 But an easy fix. Drill 1/8" hole in aluminum plug. Screw in wood screw and plug pops out so you can get at the adjustment. Not a good idea if you have emissions testing unless you cover it up again. No emmisions testing where I am located. We were able to get to it and try to adjust, didnt really cleaned up the idle. We did get idle set a little higher to where it will no longer stumble. What I am definitely noticing is that this only really happens when the engine is cold, once I get here a little warmer in shes wont stumble & is idling higher. When I take her home for lunch it idles fine, albeit high since thats where we have her set. I am still yet to even order a weber. Quote Link to comment
